Zalman CNPS9900 MAX CPU Cooler Released For $79.90
Zalman sent us word that they launched a new CPU Cooler called the CNPS 9900 Max and it looks pretty sweet. Zalman says that the CNPS 9900 MAX will decrease your CPU temperatures by 3C when compared to the CNPS9900A LED. The CPU Cooler uses a composite heatpipe, a switching noise eliminated 135mm quiet LED fan and is compatible with Intel 1156/1366/775 & AMD AM3/AM2+/AM2 platforms. The Zalman CNPS 9900 Max is available in either red or blue with an MSRP of $79.90.
Zalman CNPS 9900 MAX (Blue / Red LED) CPU Cooler Key Features:
- Heat is effectively dispersed by using composite heatpipe with greater than 1.5 times the heat transfer rate of normal heatpipe and aerodynamically designed heatsink.
- Switching noise eliminated 135mm Blue or Red fan incorporated for powerful cooling performance in the ultra quiet operation
- PWM Fan automatically adjusts fan speed(RPM) according to the CPUs temperature, while the included resistor cable(RC7P) provides the option of reducing the input voltage for overall reduction of fan speed and noise.
- Black-pearl nickel plating for long term corrosion resistance reinforce its powerful aesthetics with high intensity blue & red LEDs.
- Extreme performance super thermal grease ZM-STG2 maximizes heat transfer from the CPU to the base of CNPS9900 Max for intensified cooling performance.
- Versatile compatibility of a broad range of socket Intel 1156/1366/775 & AMD AM3/AM2+/AM2.
