Zalman CNPS9900 MAX 135mm CPU Cooler Review
System specs
Intel Test Platform | ||
Processor | Intel Core i7 930 | Click Here |
Motherboard | Intel DX58SO | Click Here |
Memory | Kingston DDR3 3GB 1333MHz ValueRAM | Click Here |
Video Card | EVGA GTS450 | Click Here |
Hard Drive | Western Digital 250gb SATA | Click Here |
Power Supply | NZXT HALE90 750W | Click Here |
Chassis | Cooler Master HAF 912 | Click Here |
Operating System | Windows 7 Professional (64bit) | Click Here |
Test procedure
To test the coolers the system will be left idle at the desktop for 30 minutes and the temp recorded. Then it will run at full load with Prime95 Blended test for 30 minutes and the temperature will be recorded. There will be 3 levels tested with our Core i7-930 clocked at a stock 2.8 GHz, a mild OC of 3.5 GHz and a high OC of 4.0 GHz. All temps will be recorded with CoreTemp, and the temp reading from all 4 cores will be averaged. The thermal paste used on all coolers will be Gelid GC Extreme.
Coolers Tested
- GlacialTech Alaska
- Intel retail box Cooler
- Prolimatech Super Mega
- Zalman CNPS9900 MAX
