Xigmatek Loki, Gaia and Aegir CPU Cooler Review Roundup
Looking at the Aegir SD128264
The Aegir is the biggest of the group. It is the same height as the Gaia, 159mm, but it is 10mm wider and deeper than the Gaia. The Aegir also comes with a 120mm fan and can be setup for two in a push/pull configuration. The included 120mm is a PWM fan running 1000-2000 RPM at 20dBA and pushing 89.45 CFM. The fan is also an LED fan, but unlike most coolers that have a blue or red LED the Aegir comes with a white LED fan.
Features of the Aegir SD128264
- H.D.T. (Heat-pipe direct touch) technology.
- Support for LGA775/1156/1366; AM2/AM2+/AM3.
- Dual fan installed option and Anti-vibration rubbers attached.
- Double layer HDT & Double performance. 2pcs 8mm & 4pcs 6mm high performance heat-pipes.
- PWM fan to adjust the power of the fan efficiently.
- Anti-vibration rubbers prevent vibration and absorb noise.
- Mounting system, Spring-Screw and consolidate back plate.
- Friendly installation.
Specifications of the Aegir
- Product Name: Aegir SD128264
- Product Number: CAC-SXHH6-U02
- Dimension: 130(W) x 66.4(D) x 159(H) mm
- Heat Sink
- Base Material: H.D.T.(Heat-pipes Direct Touch)
- Fin Material: Aluminum Alloy
- SPEC: 8mm & 6mm
- Qty: 2pcs. & 4pcs.
- Dimension: 120(W) x 120(H) x 25(D) mm
- Voltage Rating: 12V
- Start Voltage: 7V
- Speed: 1000~2200 R.P.M.
- Bearing Type: Long Life Bearing
- Air Flow: 89.45 CFM (Max.)
- Air Pressure: 4.1 mmH2O (Max.)
- Life Expectance: 50,000 hrs
- Noise Level: 20dBA (Max.)
- Available color: white LED
- Connector: 4 Pin with PWM
The fin profile of the Aegir is symmetrical and, like the Gaia, the channels for the fan mounts are in the corners on the sides.
The Aegir has an interesting heatpipe arrangement. There are 6 heatpipes in all, but 2 of those are sitting on top of two other heatpipes. There are two 6mm pipes to the outer edges and two 8mm heatpipes in the center.
On top of the two center 8mm heatpipes sits another pair of 6mm heatpipes.
Xigmatek provides everything that is needed to mount the Aegir to any of the Intel LGA sockets and AMD K8, AM2, AM3 sockets. Also included are enough fan mounts to mount two fans, and thermal paste.
The only thing I could see that could be of concern is that the mounting bracket on the motherboard got very close to the heatsink around the CPU socket. So if you have large heatsinks that are close to the socket you could have issues.
Here we have the Aegir installed in the test system and running. The LED fan was enough to light the inside of the case nicely.
