WD My Passport Edge 500GB Portable Hard Drive Review
Performance w/ CrystalDiskMark and ATTO
CrystalDiskMark v3.0.2c
CrystalDiskMark is a small HDD benchmark utility for your hard drive
that enables you to rapidly measure sequential and random read/write
speeds.
1000MB Files Test Benchmark on the My Passport Edge 500GB:
With the latest USB 3.0 drivers installed on our test system we were seeing the WD My Passport Edge 500GB USB 3.0 portable drive reached 122.9 MB/s read and 121.1 MB/s write in the sequential test. Not bad performance numbers from a 5400 RPM notebook hard drive, but we are clearly limited by the hard drive and not the USB 3.0 interface.
ATTO Disk Benchmark v2.47
ATTO is one of the oldest hard drive benchmarks that is still used today. ATTO measures transfers across a specific volume length. It measures raw transfer rates for both reads and writes and places the data into graphs that you can easily interpret. The benchmark was run with file sizes from 0.5kb through 8192kb with the total length being 256mb.
Benchmark Results: The WD My Passport Edge 500GB USB 3.0 drive hit 123 MB/s read and 120 MB/s write, which are solid performance numbers once again.
