Verizon Ellipsis 7 4G LTE Tablet Review
Verizon Ellipsis 7 4G LTE Tablet Network Performance & Battery Life
Average Download |
Average Upload |
Maximum Download |
Minimum Download |
Maximum Upload |
Minimum Upload |
Verizon Ellipsis 7 4G LTE | 21.67Mbps | 11.92Mbps | 59.39Mbps | 4.83Mbps | 17.83Mbps | 4.42Mbps |
The Verizon Ellipsis 7 4G LTE tablet running on the Verizon network was able to hit the fastest 4G LTE speed that I have seen. The maximum download speed that I saw on Speedtest.net was 59.39Mbps! The slowest download speed seen was 4.83Mbps which is still a reasonable speed to surf the web with. The average of the 20 runs sitting pretty at 21.67MbpsThe upload speed wasn’t quite as impressive as the download speed, but was still plenty fast with a maximum speed of 17.83Mb/s and a minimum speed of 4.42
Verizon Ellipsis 7 4G LTE 4,000 mAh Battery |
Google Nexus 7 | Haier Digital2 D2-961G 4400mAH Battery |
GFXBench 3.0 Battery Test | 269 (4.8FPS) | N/A | 497(8.9FPS) |
GFXBench 3.0 Battery Life | 475 minutes | N/A | 223 Minutes |
Real World Battery Test | 379 Minutes | N/A | N/A |
When you’re on the go, battery life is always important. The GFXBench 3.0 suite has a built in battery test within it. Running the GFXBench 3.0 Battery test on the Verizon Ellipsis 7 4G LTE tablet we got a score of 269 points and the benchmark was running at 4.8 frames per second and is estimated to last 475 minutes. The Haier Digital2 D2-961G scored 497 points at 8.9 frames per second and is estimated to last 223 minutes. I wanted to get a real sense of the battery life on the Verizon Ellipsis 7 tablet so I ripped a bluray and converted it to a universal format in Handbrake and looped it continually until the tablet was dead. Iron Man 3 was run from 100% to 0% in 379 minutes (6hours 19 minutes).
