V3 Components Voltair TEC CPU Cooler Review
V3 Voltair TEC CPU Cooler Benchmarking
In the benchmarks that will be run, we used an Intel 4770k clocked at 3.5GHz with Turbo Boost and the low power state enabled. Turbo Boost allows the 4770k to hit up to 3.9GHz right out of the box. Many of the previous tests we chose not to overclock beyond the turbo frequency in order to show you what your average user would see, but we did find the limits of this particular processor without going too extreme on the voltage and will start to include those results. The 4770k will be overclocked to a 4.3GHz turbo boost at 1.270 volts, which is over the stock 1.193v. To push this particular 4770k stably to 4.4GHz required well over 1.4 volts, which the performance gains of a 100MHz increase was not worth that huge bump in voltage.
To record temperatures, we used Core Temp, logged the temperatures for 15 minutes or while each program was active, and averaged all 4 cores. We left the fan settings alone, so the fans were running at roughly 1840 RPM during testing.
Benchmark wise, we will be using several synthetic and real-world benchmarks to perform normal, heavy, and extreme load. The benchmarks that I’m going to use today include: Prime95, x264, 3DMark 2013 (Firestrike test only), Metro Last Light, and Sleeping Dogs. Prime95 will peg all four cores and eight threads to 100% with the In-Place Large FFT test, which will help us to understand exactly how hot this CPU can get with each cooler.
I have reviewed several other liquid CPU coolers in the past and you will find them in the charts below for comparison purposes. I did not start overclocking the 4770k until after the Cooler Master Glacer 240L review, so not all coolers were tested under the increased stress of an overclock.
Idle
Prime95
X264
3D Mark 2013
Metro Last Light
Sleeping Dogs
Overall Results: For an air cooler, I must say the V3 Components Voltair TEC CPU Cooler did quite well in comparison to the liquid CPU coolers. Did it smoke any of them or come close to being up top? Not at all. The Voltair actually struggled as more and more load came upon it, and ultimately unable to keep the CPU cool enough for the 4.3GHz clock and Prime95 test. ***Prime95 ended up blue screening after 6 minutes of testing, so the number that you see above is what logged in Core Temp before the system restarted. If more voltage were to be applied, the CPU would have ended up throttling itself or we would have seen a BSoD sooner yet when running Prime95.
