Ultra Products 1200 Watt Uninterruptible Power Supply
General Specifications
Ultra 2000VA Features
- Line Interactive Design
- AVR (Automatic Voltage Regulation)
- Fully Digitized Microprocessor Controlled
- Protects up to 4 Devices at Once
- Energy Saving Function (UPS Green Mode)
- 50/60Hz Frequency Auto Sensing and Selection
- USB Communication Port
- Advanced Battery Management (ABM Technology)
General | Model | 2000VA |
Watts | 1200 | |
Backup Time | About 80-90 Minutes | |
Net Weight Kg (lbs) | 14.5 (31.93) | |
Shipping Weight Kg (lbs) | 15.9 (35.02) | |
Digital Display | Yes | |
Output | Voltage (on battery) | Simulated sine wave at 100V / 110V / 115V / 120V or 220V / 230V / 240V +/- 5% |
Frequency (on battery) | 50 or 60 Hz +/-1Hz | |
Voltage Regulation( AVR) | AVR automatically increase output voltage 15% above input voltage if -9% to -25% of nominal. |
AVR decrease output voltage 13% below input voltage if +9% to +25% of nominal |
Transfer Time | 2 / 4 milliseconds, including detection time | |
Input | Voltage | 100V / 110V / 115V / 120V or 220V / 230V / 240V +/- 25% at line input |
Frequency | 50 or 60 Hz +/- 10% (auto sensing) | |
Protection & Filtering | Spike Protection | 2100 Joules |
Unit Input | Breaker or fuse for overload & short circuit protection | |
Overload Protection | UPS automatic power off if overload exceeds 110% of nominal at 60 seconds and 130% at 3 seconds |
Telephone Protection | RJ-11 (1 in 2 out* or 1 in 1 out) compatible jacks for telephone surge protection. |
Ethernet Protection | RJ-45 compatible jacks for Ethernet network surge protection | |
Coaxial Protection | F1 terminal for cable TV/modem surge protection | |
Short Circuit | UPS output cut off immediately or input fuse protection | |
Battery | Type | Sealed, maintenance-free lead acid |
Typical Recharge Time | 6 hours (to 90% of full capacity) | |
Protection | Auto discharge protection | |
Interface | Dimension WxDxH (mm) | 130 x 382 x 192 (5.1″ x 15.0″ x 7.6″) |
Input Inlet | IEC 320 power inlet | |
Receptacles | NEMA 5-15R (UPS outlets x 4 , Convenience outlets x 2 ) | |
IEC 320 female appliance coupler | ||
(UPS outlets 4 , Convenience outlets x 1 ) | ||
USB / RS-232 | Detect battery low, Schedule UPS on/off, AC input/output power status display |
Alarm | Battery Back-up | Slow beeping sound (about 0.47 Hz) |
Battery Low | Rapid beeping sound (about 1.824 Hz) | |
Overload | Continuously beeping sound | |
Environment | Ambient Operation | 3,500 meters max, elevation. 0-95% humidity non-condensing, 0-40 deg |
Audible Noise | <40dBA (1 meter from surface) | |
Storage Condition | 15,000 meter max. elevation |
