Thermaltake Water2.0 Pro CPU Cooler Review
Looking closer at the Water2.0 Pro
The Water2.0 Pro at first glance looks like the Antec H2O 920 or the AMD water cooler that was also made by Asetek. What is missing is the USB connection and fan controller connections on the pump housing. The hoses are still flexible rubber and 13 inches long. The only power lead is a 3 pin connector for the pump.
The pump housing has the Thermaltake Water2.0 logo printed on it. Unlike any of the recent Asetek based kits, the logo is not back lit. The tubing is connected to the pump with 90 degree swivel fittings.
The base comes with thermal paste pre-applied and protected with a plastic cap.
Under the stock paste is a nice smooth base.
The radiator is all aluminum. It stands 6″ tall.
4.75″ wide.
And just shy of 2″ thick.
The fin count comes in at 20~21 fins per inch, just like all the recent Asetek units.
A pair of 120mm fans with 4-pin fan headers come with the Water2.0 Pro water cooler. They run at a max speed of 2000 RPM pushing 81.32CFM at 27.36dBA.
