Thermaltake Water 3.0 Ultimate CPU Cooler Announced
Thermaltake: Water 3.0 Ultimate All-In-One Liquid Cooling System to Exceed Your Expectations!
Thermaltake Water 3.0 Ultimate All-In-One Liquid Cooling System to Exceed Your Expectations
Taipei, TaiwanJuly 25th , 2014�Thermaltake, being an industry leader in computer chassis, thermal solutions, and power supply units today launch the new Water 3.0 Ultimate, an All-In-One liquid cooling system with an large 360mm radiator design especially to support the desires of enthusiasts. Equipped with power as well as performance, Water 3.0 Ultimate is top of the line liquid cooler, compatible with universal socket type. When choosing a highly-efficient liquid cooler to control any escalating CPU temperatures, gamers definitely take easy, clean, and low-maintenance setup in consideration. And Water 3.0 Ultimate can be their best choice! The new Thermaltake All-In-One LCS Water 3.0 Series is designed to exceed user expectations. One simple upgrade allows users to enjoy a better cooling performance with superior CPU protection.
Features of Water 3.0 Ultimate are as follow:
Thermaltake Water 3.0 Ultimate with high performance waterblock, the high performance copper base plate accelerates the heat conductivity
High Performance Waterblock
The high performance copper base plate accelerates the heat conductivity. Additionally, the pre-refilled coolant reduces any stress from liquid replenishment hassle.
Thermaltake Water 3.0 Ultimate with high efficiency radiator
High Efficiency Radiator
The specially designed 360mm large surface radiator not only doubles the cooling surface, but also supports up to 6 x 120mm fans for additional heat dissipation.
Triple Curve Fans
The triple 120mm PWM fans provide an instantaneous cooling function. The powerful PWM controlled fan speed is between 1000~2000rpm, reducing the radiator heat from the chassis to maximize cooling off performance.
The high quality and reliable pump of Water 3.0 Ultimate enables the maximum amount of water circulation, keeping the copper plate continuous
High Reliability Pump
The high quality and reliable pump enables the maximum amount of water circulation, keeping the copper plate continuously cool. The low evaporation tube effectively decreases the loss of coolant; therefore no refill is either needed or required.
Thermaltake Water 3.0 Ultimate All-In-One Liquid Cooling System provides a simple installation system
Easy and Simple Installation
The Water 3.0 Series� Water 3.0 Ultimate, Water 3.0 Extreme, Water 3.0 Pro and Water 3.0 Performer feature the latest cooling performance technology from Thermaltake, providing a simple installation system, and a totally maintenance-free operation. The Water 3.0 Series is easy to install and requires the minimum amount of space in the chassis.
For more information on the Thermaltake Water 3.0 Ultimate information please visit: http://www.thermaltake.com/Cooling/Liquid_Cooler_/All_in_One/C_00002345/Water_3_0_Ultimate/design.htm
