Thermaltake Water 3.0 Extreme S AIO CPU Cooler Review
Benchmarking the Thermaltake Water 3.0 Extreme S
In the benchmarks that will be run, we used an Intel 4770k clocked at 3.5GHz with Turbo Boost and the low power state enabled. Turbo Boost allows the 4770k to hit up to 3.9GHz right out of the box. Many of the previous tests we chose not to overclock beyond the turbo frequency in order to show you what your average user would see, but we did find the limits of this particular processor without going too extreme on the voltage and will start to include those results. The 4770k will be overclocked to a 4.3GHz turbo boost at 1.270 volts, which is over the stock 1.193v. To push this particular 4770k stably to 4.4GHz required well over 1.4 volts, which the performance gains of a 100MHz increase was not worth that huge bump in voltage. Also understand that every processor reacts differently to voltage adjustments, so some may run slightly cooler or hotter at this same overclock frequency.
Benchmark wise, we will be using several synthetic and real-world benchmarks to perform normal, heavy, and extreme load. The benchmarks that we’re going to use today include: Prime95, x264, 3DMark 2013 (Firestrike test only), Metro Last Light, and Sleeping Dogs. Prime95 will peg all four cores and eight threads to 100% with the In-Place Large FFT test, which will help us to understand exactly how hot this CPU can get with each cooler.
I have reviewed several other liquid CPU coolers in the past and you will find them in the charts below for comparison purposes. I did not start overclocking the 4770k until after my Cooler Master Glacer 240L review, so not all coolers were tested under the increased stress of an overclock.
Idle
Prime95
X264
3D Mark 2013
Metro Last Light
Sleeping Dogs
Overall Results: My expectations were for the TT Water 3.0 Extreme S to perform similar or slightly worse than the Corsair H105, or perhaps the NZXT Kraken coolers – I must say, I was fairly impressed with that guess. It didn’t match the either the H105’s or the Kraken cooler’s numbers, but it stuck pretty darn close. I feel that if Thermaltake included a more efficient fan, this could have helped it keep pace even better. Not knowing the full specs of the fan, it’s tough to say how much they could have improved. Of course the radiator included with the Corsair H105 is thicker by design, or the Kraken x60 is 280mm vs. 240mm, which does help with the higher loads that Prime95 or x264 put on the processor.
