Thermaltake Toughpower DPS Power Supplies Announced
Revolutionary digital-controlled power supply with software Thermaltake Toughpower DPS
Taipei, Taiwan September, 5 2013 Thermaltake, being an industry leader in computer chassis, thermal solutions, and power supply units announces the latest news that the new revolutionary Thermaltake Toughpower DPS 850W/750W, an innovative digitally- controlled power supply with software. The implementations come with better voltage regulation to provide the system with clean and stable power. Of all the PSU monitoring software applications in the marketplace, Thermaltake DPSApp is the supreme monitoring tool that is powerful, easy-to-use, flexible and universal all in the same package.
Concept
- Monitor the electricity cost of your PC to help users manage the power expense.
- Record the status of your PC which enables active monitoring and the ability to organize the data to a quantitative database.
- Sharing in the cloud to provide users the ability to share results with friends.
Smart DPSApp Software
The easy-to-use DPSApp is available for download on the Thermaltake website. (http://www.thermaltake.com/tempdownload.aspx?type=PSTPG0850) The software enables users to digitally calculate the electricity cost, monitoring efficiency, wattage and voltage of the power supply with innovative technology.
Calculate the electricity cost
As the software digitally calculates the electricity cost, it can be helpful for expense control and management.
Monitor the Wattage, Efficiency & Voltage
The software enables users to monitor the wattage change, efficiency and voltage while using the computer, such as playing games, internet browsing, etc.
With no connecting boundaries, DPSApp provides users an impeccable function to share power usage results with friends through social network applications such as Facebook, Twitter, and Weibo, or by sending reports via e-mail.
Quantitative Database Management
Organize and save records to view within the database of usage in detail. Each record contains usage up to a 6-hour period.
Digital Fan-control
Monitor and adjust the fan speed of the Power Supply in either silent or performance mode through the DPSApp.
Fully Modular Cable Design
The fully modular cabling design allows use of cables users need resulting in improved optimal airflow and reduced system clutter.
For more details on the Thermaltake Toughpower DPS information please visit:
Thermaltake Toughpower DPS 750W: http://www.thermaltake.com/products-model.aspx?id=C_00002107
Thermaltake Toughpower DPS 850W: http://www.thermaltake.com/products-model.aspx?id=C_00002106
