Thermaltake Riing 12 and 14 LED Radiator Fans Released
Thermaltake Riing 12 and 14 LED Radiator Fan Series
High-Static Pressure, High Efficiency, and Low Noise Radiator Fan with 4 Colors Patented LED Ring
Taipei, TaiwanFebruary 26th 2015Thermaltake, an industry leader in computer chassis, thermal solutions, and power supply units, introduces the new Riing 12 and 14 LED Radiator Fan Series, patented LED ring radiator fan fitted to enhance static pressure that produces impressive cooling performance with an optimized fan blade design. Hydraulic bearings for silent operation guarantee ultra-low noise. In addition, an anti-vibration mounting system strengthens the stability during operation. The patented LED Ring maintains color and brightness uniformity, available in four colors: blue, red, white, and green to add style to the chassis, allowing users to not only build up an aesthetically superior liquid cooling system but also incorporate externally-modular upgrades for their chassis. The new Thermaltake Riing 12 and 14 LED Radiator Fan Series will soon be available on Newegg around the end of February.
Thermal Image Test - Thermaltake Riing
Thermal Image Test
Compared to the standard case fan, the combination of three Riing 12 radiator fan and RL360 radiator (Outlet and inlet water temp. are 49 and 44.5 in respective, T= 4.5) decreases around 2 by delivering 40% better cooling performance.
More details about Riing 12 and 14 Radiator Fan Series:
Concentrated Compression Blade
Custom designed for high-static pressure requirements of demanding applications such as radiators, the Concentrated Compression Blade (CCB) is engineered to focus the inner weaker circle of air outwards, allowing the outer section to pressurize and compress the air.
Wind Blocker Frame
The wind blocker frame is designed to work with the Concentrated Compression Blades (CCB) pressure mechanism by directing airflow towards the middle section of the blade, thereby creating a compression effect and blocking any pressure from escaping. This reduces the blades noise and vibration, creating a perfect balance between power and sound.
Hydraulic Beairng with Low-Noise Design
The hydraulic bearing self-lubricates with a high quality, friction-reducing substance which lowers operating noise and improves efficiency. The seal cap prevents leakage of the lubricant, and improves the lifespan of the unit. The LNC (Low-Noise Cable) can reduce the noise level around 21% to 24%.
Anti-vibration Mounting System
In-mold injection anti-vibration rubber pads provide hassle-free usage for 80% protection coverage, including all four corners.
Four Colors of the Patented LED Versions Available
Riing 12 and 14 LED Radiator Fan Series is available with different LED versions (red, blue, green, and white), adding cooling aesthetics to the chassis.
Riing Specifications
For more details on the Thermaltake Riing 12 and 14 LED Radiator Fan Series please visit:
Riing 12 LED Blue http://www.thermaltake.com/products-model.aspx?id=C_00002638
Riing 12 LED Red http://www.thermaltake.com/products-model.aspx?id=C_00002640
Riing 12 LED Green http://www.thermaltake.com/products-model.aspx?id=C_00002639
Riing 12 LED White http://www.thermaltake.com/products-model.aspx?id=C_00002641
Riing 14 LED Blue http://www.thermaltake.com/products-model.aspx?id=C_00002634
Riing 14 LED Red http://www.thermaltake.com/products-model.aspx?id=C_00002636
Riing 14 LED Green http://www.thermaltake.com/products-model.aspx?id=C_00002635
Riing 14 LED White http://www.thermaltake.com/products-model.aspx?id=C_00002637
About Thermaltake
Thermaltake Technology was established in January, 1999 and has been market to the world with Thermaltake brand name ever since. The brand personality of Unique, Aggressive, Vivid, and Stylish makes Thermaltake an expert in creating Exciting things and Fascinating environment for gamers and enthusiasts, also Keep them Constantly High physically and mentally.
Moreover, Thermaltake Technology get close to consumers and observe lead users behavior and requirement, to design aesthetic and high quality products which will greatly improve system performance and bring the user to the up most potential. With innovative design and unique style, Thermaltake products spread rapidly among the enthusiasts in DIY market and soon become the number one choice for PC DIY enthusiasts worldwide.
