Thermaltake Outs PSU and Liquid Cooling System with RGB LEDs
Thermaltake is at Computex 2017 and the company is showing off some cool new products at the show. One of the new products is a modular power supply with 1250W called the Tough-Power iRGB Plus 1250W- TT Premium Edition. The PSU has perforated panels all around for style and cooling along with a 140mm fan that has RGB LEDs for color.
The PSU has an 80 Plus Titanium certification and promises serious electrical protections. The PSU also has a USB port to allow the user to monitor performance and control the system. The PSU is 7.9-inches deep so if you want to partake, be sure you get a chase that will handle something that massive.
Thermaltake also has a new chassis that appears to sport metal and tempered glass called the View 71 TG Edition PC chassis. The chassis is for E-ATX boards and will support CPU coolers up to 190mm tall and graphics cards up to 16.1″ tall. There are four tempered glass panels allowing you to see inside from the top, sides, and front. It comes with two 140mm fans, but can fit three more in the front and the ability to fit 420mm radiators in the front and top panels.
Thermaltake has made self-contained liquid cooling systems for a long time and it has a new and suitable blingy liquid cooling offering at the show. The system is called the Floe Riing RGB TT Premium Edition and aside from the unfortunate spelling of the name, it’s very cool. It packs RGB LED waterblock and three fans with the same lighting. You can get the cooling system in 240mm, 280mm, or 360mm size and the lighting and performance is controlled via software. Pricing on all these new products is unannounced according to TechReport.
