Thermaltake Launches Toughpower Grand Series Power Supplies
Thermaltake Technology today announced the latest addition to the popular Toughpower line of high-end PC power supply units, the Toughpower Grand Series. Its grandiose looks with a classy black finish make a clear statement through sheer appearance: this is quality pure. The proprietary 14cm dual-ball-bearing flower-shaped fan provides optimized ventilation for the inside components of the Tougherpower Grand unit. Being 80 PLUS Gold certified users dont just get a guaranteed eco-friendly PSU with more than 90% efficiency at 50% load and a 0.95 active power factor correction (PFC), but the electricity bill will noticeably drop as well. By virtue of their high-efficiency, the Toughpower Grand 650W (750W peak) and 750W (850W peak) models are ideally suited for high-end gaming and enthusiast PCs powering multi-core processors in combination with multi-G! PU setups.
Thermaltake Toughpower Grand Power Supply Series
For demanding mission-critical environments and applications, industrial-grade components are indispensible and are being tested 24/7 at 50C to ensure utmost stability and long-term reliability. The Japanese made and solid state capacitors withstand up to at least 105C of heat serving as robust foundation for the Toughpower Grand Series. Additional DC-to-DC converter modules for +3.3V and +5V rails ensure low A/C ripple and great system stability. The convenient Cable Management allows you to only connect those components power cords that you actually need, this helps to decrease cable mess and increase air circulation within the case.
