Thermaltake Launches SlimX3 CPU Cooler For HTPC Systems
Thermaltake has launched their all-new low profile CPU especially targeting Home Theater PC users, the Thermaltake SlimX3. Since for Home Theater PCs usually small and mini size cases are used, the CPU cooler performance is of utmost importance, it has to come with a very small footprint in order to fit into the case, but at the same time offer sufficient cooling capacity in a silent environment.
The SlimX3 adopts two 6 mm Copper heat-pipes with an aluminum fins/base combination to provide a highly effective cooling performance for multimedia oriented CPUs. Through the heat-pipe design better heat conductivity is achieved to accelerate heat dissipation. With its slim design with a total height of only 36 mm the SlimX3 is optimized and ideal for use in most mini cases.
