Thermaltake Element G Gaming Case Review
Assembling the System
AMD Test Platform |
Component |
Model |
Pricing |
Motherboard |
Gigabyte MA790GP-DS4H |
Processor |
AMD Phenom II 940 Black Edition |
Cooling |
AMD Reference Cooler |
Memory |
OCZ Reaper PC8500 |
Hard Drive |
Seagate 7200.12 320Gb |
Optical Drive |
LG Dual Layer DVD Burner |
Power Supply |
Corsair Memory HX1000 |
Live Pricing |
Graphics Card |
XFX GTX260 Black Edition |
As you can see below fitting everything inside the ThermalTake Element G was easy. You get plenty of room to work and plenty of room for your parts to breathe.
One of the features that has bothered me with most cases with side fans was the wire and the fact that it just hangs there. This is only an issue on a case with a window. The ThermalTake Element G took care of that issue. All you have to do is plug in the molex connector that is easily hidden behind the motherboard tray. The power then runs to a set of contacts that match up with a set of contacts on the side panel. Granted there isn’t a window, but it is a much easier way to run this wire. I do hope this is integrated into more cases from ThermalTake, especially the ones with windows in them. The only drawback I see is that there is no protection from the contacts if the side panel is off.
