Thermaltake Chaser MK-1 Case Review
Installing parts into the Thermaltake Chaser MK-1
The Chaser MK-1 comes with everything that is needed to install your parts. Thermaltake also includes a 5.25 to 3.5 drive bay adapter and face plate, along with an 8 pin extension cable.
Installing the system was quick and easy. During the install process I never hit a snag or felt frustrated while installing the parts.
With the case lit up the Chaser MK-1 looks nice, and the window shows off the Zalman CNPS11X CPU cooler I have installed on the test system.
The LED accent light on the front around the power button is not super bright, but will catch your eye. The accent also pulses on and off while the system is powered up. In the upper corner of the reset button the red LED is the hard drive activity light.
