Thermaltake Announces New Water Cooling Products – Bigwater A80, 760 Plus and Level 10 GT LCS
Thermaltake today announced all new water cooling kits and cases! The star of the product announcement is of course the Level 10 GT Liquid Cooling Chassis, but you also have the Bigware A80 and Bigwater 760 Plus being announced today! All three of these water cooling solutions will be available in August.
Thermaltake created a water cooled version of their popular Level 10 GT PC case and has called it the Level 10 GT LCS. It comes with an integrated drive bay liquid cooling system, consisting of an all inclusive drive bay unit and intelligent interconnecting waterblock. The slim waterblock was developed with Pure Copper Base that maximizes the thermal efficiency. Also, the Dimple Tube Technology of the radiator increases the turbulence within the radiator to perform maximum cooling action. In addition, the P500 pump pushes 500L/H of water to improve the overall cooling efficiency and performance level. Furthermore, the Ultra quiet pump, 12CM blue LED fan and water reservoir are all preinstalled inside the drive bay unit to achieve maximum performance.
Bigwater A80 is an all-in-one device that has every aspect little detailed parts carefully designed to its details. Bigwater A80 satisfies the core elements of a Liquid Cooling System, cooling performance, space saving and easy installation that you look for when selecting a liquid cooling system. The pre-filled coolant offers good ability of heat conductivity, low evaporation tube decreases the loss of coolant effectively and the high-tech sealed circulation system prevents leaking issue.
BigWater 760Plus, the new 2U drive bay liquid cooling system, is designed for advanced LCS lovers. Ultra quiet pump, 12CM blue LED fan (fan speed from1600~2400 RPM) and water reservoir are all strategically positioned inside the drive bay unit to achieve maximum performance and extreme space saving! In the meantime, the P500 pump pushes 500L/H of water to improve the overall cooling efficiency and performance level; the Dimple Tube Technology of the radiator increases the turbulence within the radiator to enlarge the coolant contact surface and extend the time coolant stay in the radiator to perform maximum cooling action.
Level 10 GT LCS Features:
- FrontSpeed 2: USB 3.0 SuperSpeed
- PitStop 5: EasySwap HDD bays
- TripleMax: Ready for extra-long graphics card up to 14.2/36 cm
- QuadFan: Maximum ventilation and cooling
- Triple Colorshift: Adjustable fan ambience colors
- CableClear: Advanced cable management
- S.S.S.: Smart Lock Security System
- CoolFlux: Bigwater 850GT water-cooling integrated
