Thecus Technology Launches First Portable Storage Drive With USB 3.0 – D0204
Thecus Technology announced its first portable storage device featuring the new USB 3.0 standard the D0204. With massive storage capacity in a tiny package no larger than a paperback book, the D0204 delivers impressive data security and performance with an integrated USB 3.0 port, making it the most powerful and versatile portable DAS on the market. Wrapped in a housing measuring a mere 86mm x 55.3mm x 132mm, the D0204 may appear to be a mere portable hard disk at first glance, but peering inside this tiny form factor reveals a powerful storage unit.
Headlining is its integrated USB 3.0 port at the back of the unit, which grants the D0204 data transfer speeds of up to 5Gb/s ten times the speed of USB 2.0. With USB 3.0 built-in, users can transfer files to and from the device at unprecedented speeds with a USB 3.0-enabled computer. Of course, the D0204 is fully backward-compatible with USB 2.0 and USB 1.1 standards, which means you can use it with virtually any USB-equipped device.
