Supertalent Fireball 512MB Flash Drive Review
Features
The Fireball sports a thick rubber casing, making for a very rugged and shock-resistant body. It features the familiar cap design, also rubber, and an LED on one side. To give it some flair and most likely gamer appeal, Super Talent has etched a fireball pattern onto both sides of the case and makes for a very unique drive.
Here is Super Talent?s Specifications:
- Full Compatibility with USB 1.1 and 2.0
- Dual Channel Flash Memory Architecture
- Hot Plug and Play – Insert and Function Like Another Hard Drive
- Supports Auto Run (Upon Special Request) – Insert and Auto Play like CD-ROM
- Supports Password Protection
- No Driver Needed for Most Windows O.S.
- (Windows 98SE Driver Needed and Available On-Line)
- More Than 10 Years Data Retention
- Dual LED Indicates Power On, Data Transfer, Busy
- Warranty: life time
This drive can be found in both 1 and 2 GB sizes. And as stated, can be found in the $45-$60 dollar range on-line.
One of the major bonuses of a Super Talent product is the life time warranty. Super Talent makes a point to stand behind its product and is apparent. With a little digging I found that they will even mail you a replacement cap for any flash drive they make for free?as long as you send them the prepaid envelope in which they will send it in.
