Super Talent RAIDDrive 64GB USB 3.0 Flash Drive Review
SiSoftware Sandra 2010
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility. Sandra provides most of the information (including undocumented) you need to know about your hardware, software and other devices whether hardware or software. In order to test the hard drive, SiSoftware Sandra 2010c was used as part of the test suite. The graphical results that Sandra gives you after the test is completed nicely shows how drives perform over time and where on the drive the performance is seen.
USB 2.0 Header & Super Talent USB
Driver:
USB 3.0 Header & Super Talent USB
Driver:
Benchmark Results: The removable storage test in Sandra 2010 showed the drive was able to nearly 290X speeds in the 256MB Files test on USB 2.0 and 1078X on USB 3.0! The Super Talent RAIDDrive is without a doubt the fastest USB Flash drive that we have ever tested!
We had a reader ask about USB 3.0 sequential read/write speeds on the AS SSD Benchmark, so we tossed up the results here for that as well in case someone else was curious.
