Spire Introduces Star LED Fan Series
Spire today introduced the Star LED PWM series of case fans. Spire is making them available with either RedStar and BlueStar LED lighting and in 80mm, 92mm and 120mm fan sizes. Spire believes that these UV-Reactant fans will me a great addition to any PC. The 120mm version has a maximum airflow of 51.12 CFM, spins between 600 and 1200 RPM and uses 1.32 Watts of power. The noise level is said to be between 10 to 23 dBA. Spire even sleeved the 4-pin cable for better airflow and looks, so these look like very nice fans and are backed by a 3-year warranty. The Redstar 120 LED PWM fan below is available at $12.99 (sleeve beating), $14.99 (ball bearing) or $19.99 (nano bearing).
Spire RedStar
Spire Star LED Fan Features:
  • Special fan blade shape and spokes design, ultra silent operation
  • 4 fire-red LEDs installed
  • Superior airflow and High air pressure
  • PWM automatic fan speed control as a standard
  • Sleeved wires for better airflow, and neat appearance
  • 4 PIN PWM (2510) connector for mainboard
  • UV-Reactant
The Spire Star LED fans are high quality, LED colored and silent cooling fans for the PC gamer and PC enthusiast. Based on the original Star fan blade design these new LED series are destined to be a big hit. Top of the line components and features are applied to build these powerful LED fans. This version of the RedStar LED fan features PWM which automatically controls the fan speed, according to the computers temperature. This ensures that the fan is a quiet as possible at all times and automatically adjusts to meet your systems cooling needs. To make the Star fan series extra silent we have included 4 rubber anti-vibe mounts to install the fan and stop any fan vibration.
