Silicon Power US70 1TB NVme SSD Review
AS SSD Benchmark
AS-SSD (2.0.7316.64247) Benchmark:
We have been running the AS-SSD Benchmark app for over some time now and found that it gives a broad result set. The programmer has worked very hard on this software and continues to make updates often so if you use it, show him some love and send him a donation. There are now three tests that are found within the tool and we’ll show the results from all three of them.
AS SSD:
Benchmark Results: On AS SSD Benchmark, the Silicon Power US70 1TB NVMe SSD topped out at 4,170.85 MB/s read and 3,972.42 MB/s write with an overall score of 6,034 points.
AS SSD Copy:
AS SSD Compression:
Benchmark Results: For this benchmark chart you would ideally want to see a straight line as you dont want any compression performance loss as the test goes from 0% compressible to 100% compressible data during the benchmark test period. Performance seems to gets slightly better as the level of compression increases. We noticed several decent sized performance drops during the write test, but this is something we’ve commonly seen on products using the Phison E16 controller.
