Silent Pro Gold Power Supply Series Released by Cooler Master
High-end computers are getting more and more demanding when it comes to power requirements and these days its not good enough to have any old power supply if youre a demanding gamer or overclocker. The latest top of the range graphics cards from both ATI and Nvidia are demanding more power than ever before and the latest flagship motherboards are equally demanding once you start pushing the limits of your system by overclocking it. The new Silent Pro Gold series from Cooler Master addresses all of these problems while maintaining or even exceeding an extraordinary 90 percent power efficiency under load* which gains it an 80 Plus Gold certification.
The Silent Pro Gold series is available in a wide range of different Wattages, starting at 600W going all the way up to 1200W. The 700W, 800W and 900W models are all ready for 3-way SLI or CrossFireX, while the 1000W and 1200W models handles quad SLI or CrossFireX as well as the latest XL-ATX motherboards with support for dual 8-pin 12V connectors. Common across the entire range is support for no less than nine SATA drives, four Molex connectors and a single floppy drive connector. All models also come with a class leading 5 year warranty.
