Seagate Momentus XT 500GB Solid State Hybrid Drive Review
The Test System
Before we look at the numbers, here is a brief glance at the test system that was used. All testing was done on a fresh install of Windows 7 Ultimate 64-bit. All benchmarks were completed on the desktop with no other software programs running. The Intel Core i7 test system was run in triple-channel memory mode at 1600MHz with 8-8-8-24 memory timings. The ASUS P6X58D Premium motherboard was run using all the latest drives and BIOS 0702. The ASUS P6X58D Premium motherboard uses the Intel ICH10R south bridge chipset, which we used to run our ‘boot drive’. The boot drive used in our test system was an Intel X25-V 40GB model with TRIM enabled. We then used the Marvell 9123 PCIe SATA 6Gbps controller that is on the motherboard to test the SSDs that are used in the benchmark charts. All of the SSDs were tested in a fresh out of the box (FOB) state and had the latest firmware installed on them when testing was done.
The Marvell 9123 SATA 6G Controller was tested using driver version 1.0.0.1036 or 1036 for short.
Intel LGA 1366 Test Platform | |||||
Component |
Brand/Model |
Live Pricing |
Processor |
Core i7 920 | ||||
Motherboard |
ASUS P6X58D Premium
Memory |
6GB Kingston HyperX T1 1600MHz
Video Card |
ATI Radeon HD 5670 |
Hard Drive |
Intel X25-V 40GB |
Cooling |
OEM |
Power Supply |
CoolerMaster UPC 1100W |
Operating System |
Windows 7 Ultimate 64-Bit |
SSDs and HDDs Included in the Benchmarking:
- Crucial RealSSD C300 256GB – Firmware 0001
- Intel X25-M G2 160GB – Firmware 02HD
- Mushkin Callisto 60GB – Firmware 309A13F0
- OCZ Vertex 2 Pro 100GB – Firmware 232A11F0
- OCZ Vertex 2 100GB – Firmware 1.0
- OCZ Vertex LE 100GB – Firmware 1.0
- OCZ Vertex 120GB – Firmware 1.5
- Seagate Momentus 7200.4 500GB – Firmware 0002SDM1
- Seagate Momentus XT 500GB – Firmware SD22
- Toshiba THNS256GG8BBA 256GB – Firmware AGYA0201
- WD SiliconEdge 256GB – Firmware 5.12
- WD VelociRaptor 300GB – Firmware 04.04V01
- WD VelociRaptor 600GB – Firmware 04.05G04
Detailed Information on the Seagate Momentus XT Hybrid Drive:
Seagate included a reviewers guide of this drive and we wanted to share this part with you as it explains why you wont see performance improvements in some of the benchmarks that we are about to show you.
The Momentus XT Adaptive Memory technology relies on identification of usage patterns. Therefore, to
get an accurate representation of the performance it is important to repeat the benchmark at least three
times and look at the scores from the last run.
Many traditional HDD benchmarks, as oppose to those listed above (PCMark Vantage and SYSmark 07), utilize low level HDD commands to
analyze raw read/write performance of the drive under various conditions. These synthetic benchmarks,
however, are not a good measure of the actual performance benefit that an end-user will experience. This
is because the storage unit many times is not the bottleneck in real user experience. Long sustained
transfer rates do not impact the end user as much as short bursts of data transfer. How the performance
of the storage unit interacts with the host system is a complicated relationship that can only be
satisfactorily measured using scripting benchmarks that mimic end-user activity and take into account
system/storage interaction. If the additional raw performance came without a cost then the real world
benefit is inconsequential. However, if the additional performance comes at a cost it is important to
demonstrate the actual value proposition to the user.
The following programs are examples of benchmarks designed for measuring raw read/write
performance of a drive. While they represent a drive raw comparison there is not a direct correlation to
user benefit. Thus, they are not a good measure of the value of that raw performance.
- H2Bench
- HDTune
- IOMeter
- CrystalDiskMark
- PCMark 04 or PCMark 05
Let’s take a look at the benchmarks and see what the Momentus XT 500GB hybrid drive has to offer!
