RunCore Pro V Max 120GB SATA III SSD Review
RunCore Pro V Max – Real World Tests
One of the most common operations performed on a PC is moving/copying files. Using a free application called Teracopy, we copied large numbers of two file types from one folder to another on the same drive. Teracopy allows us to objectively measure the time of transfer and using the same drive prevents other devices from tainting the outcome. The operation requires the drive to perform both sustained read and writes simultaneously. The first set of files is a 5GB collection of JPG’s of variable size and compression levels with a few movie (.MOV) files thrown in for good measure since most cameras now take video as well as stills. The second is a collection of MP3 files of various sizes which totals 5GB collectively. These file types were chosen due to their wide use and mixture of file sizes and compression levels.
RunCore Pro V 120GB JPG Copy
Install Results: The RunCore Pro V Max 120GB came in the last third of the pack in terms of file copy time. This is a few seconds off the comparable SandForce drives of the same capacity and roughly 10-15 seconds behind the larger, better performing drives.
RunCore Pro V 120GB FILECOPY CHART
We also timed the installation of a few rather lengthy applications/suites as app installs is something everyone does and waiting for completion can be a drag. We used Adobe Dreamweaver CS5, Microsoft Office 2010 Professional and Futuremark’s 3DMark Vantage (v1.102.1901) as our test subjects with all install settings at default. Both were installed from an installer located on the target drive itself as installing from another drive, especially an optical drive, would cause a bottle-neck that would corrupt the results. The timing for these had to be done via stopwatch so there should be about a half second +/- error margin. Again, with the source and target drives being the same, concurrent read/write activity is required.
 DREAMWEAVER
RunCore Pro V 120GB APP CHART
Install Results: Install times were closer to the top of the pack here with times that were just seconds off the lead.
Windows Boot Times
Windows start up/shutdown time is always something people are interested in and we haven’t done it in a while because there was little variation with the majority of the SSDs. We recently began using an application called BootRacer to objectively measure the startup times of the drives. All of the instances of Windows were identical and freshly installed with only the video driver installed.
RunCore Pro V 120GB BootRacer
RunCore Pro V 120GB Boot Chart
Test Results: Though we have a limited comparison list, the boot times were right there will all of the comparison drives including within three seconds of the Intel 520 Series in a RAID 0 configuration.
We’ll wrap this with a look at the total drive capacity and our final thoughts.
