RunCore Pro V Max 120GB SATA III SSD Review
CrystalDiskMark and PCMark 7
CrystalDiskMark 3.0.1 x64 – Intel P67 Platform
Benchmark Results: Again, the RunCore Pro V Max 120GB drive does a nice job on the sequential reads but doesn’t quite keep up with some of the larger capacity SF-2281 drives but compares very well with the 120GB drives.
PCMark 7 Professional – Intel P67 Platform
We are continuing to use the new PCMark 7 software since they have updated it to version 7 which is specifically designed for Windows 7. It measures the performance of the latest PC hardware across a variety of common scenarios. PCMark Vantage 7 supports both system level and component level benchmarking and comprises several different test suites but for the purposes of this review, we employed the secondary storage suite. The nice thing about it is that you can submit your scores online and compare against others.
Benchmark Results: The overall score is very good here and the individual scores are very good as well although for the most part, this benchmark doesn’t show large variations in drive performance.
