RunCore Pro V Max 120GB SATA III SSD Review
Test System and Comparison Drives
Legit Reviews Test System
All tests were performed on a fresh and up-to-date install of Windows 7 Pro x64 with no other applications running while using AHCI mode set through the BIOS. Synthetic Benchmarks were run with the OS loaded on a 40GB Corsair Force SSD. In between every test, the test drive was secure erased using an instance of Parted Magic. As such, all results should be indicative of optimal performance. All components were set to their default speeds and are listed below. As always. we thank ASUS for their generosity and support in providing the motherboard for our test bench.
LR Test Bench
P67 Test Bench
Intel LGA 1155 Test Platform
Component Brand/Model Live Pricing
Processor
Core i5 2500k
Motherboard
ASUS P8P67 Deluxe
Memory
Crucial 2 x 2GB PC3-10600
Video Card
Gigabyte GeForce GT 430
OS Drive
Corsair Force 40GB
Power Supply
Corsair HX1000
Operating System
Windows 7 Pro 64-Bit
Comparison Drives & Other Models We Have Tested
Since there are so many SSDs out there now with different controllers, we started a reference table of which controllers are used by each drive to help you compare results. Different controllers definitely perform differently and each has various strengths and weaknesses. Like CPU’s, even identical drives will have variations in performance and part of that variance may be attributable to the NAND flash used. Since the tests of the drives listed have spanned different test benches and represent three different interfaces, we have listed them for easy reference.
SSD MODEL CONTROLLER(S) TRIM? Interface
Intel 520 Series 240GB
SandForce SF-2200 (SF-2281) Yes SATA III
Samsung 830 Series 256GB
S4LJ204X01-Y040 Yes SATA III
Corsair Force GT 180GB
Corsair Force GT 240GB
Samsung S4LJ204X01-Y040 Yes SATA III
OCZ Octane 512GB
Indilinx Everest Yes SATA III
Corsair Force 3 120GB
Super Talent TeraDrive CT3 64GB
Kingston HyperX 240GB
Corsair Force GT 120GB
Patriot Pyro 120GB
OCZ RevoDrive 3 X2 480GB
SandForce SF-2200 (SF-2281)x4 Yes PCI-E
OWC Mercury EXTREME Pro 6G 240GB
OCZ Vertex 3 Max IOPS 240GB
OCZ Agility 3 240GB
OCZ Vertex 3 120GB
PQI S535 256GB
SandForce SF-1200 (SF-1222) Yes SATA II
OWC Mercury EXTREME Pro 120GB
Crucial m4/Micron C400 256GB
Marvell 88SS9174 Yes SATA III
Intel 320 Series 128GB
Intel PC29AS21BA0 (G3 FW) Yes SATA II
Corsair Performance 3 Series 128GB
Intel 510 Series 250GB
Plextor M2 Series 128GB
Kingston V100 Series 128GB
JMicron JMF618 (Toshiba branded) Yes SATA II
OCZ Vertex 3 Pro 200GB (beta) SandForce SF-2500 (SF-2582) Yes SATA III
RunCore Pro V 120GB
Samsung 470 Series 256GB
Samsung S3C29MAX01-Y340 Yes SATA II
Zalman N Series 128GB SandForce SF-1200 (SF-1222) Yes SATA II
Kingston V+100 128GB Toshiba T6UG1XBG Yes SATA II
Corsair Force 40GB Sandforce SF-1200 (SF-1222) Yes SATA II
Intel X25-V 40GB Intel PC29AS21BA0 (G2 FW) Yes SATA II
G.Skill Phoenix Pro Sandforce SF-1200 (SF-1222) Yes SATA II
Patriot Inferno 100GB Sandforce SF-1200 (SF-1222) Yes SATA II
OCZ RevoDrive X2 240GB
4X SF-1200 (SF-1222) No* PCI-E
OCZ RevoDrive 120GB
2X SF-1200 (SF-1222) No* PCI-E
ADATA S596 128GB JMicron JMF612 Yes SATA II
Corsair Force Series 120GB Sandforce SF-1200 (SF-1222) Yes SATA II
Patriot Zephyr 128GB JMICRON JMF612 Yes SATA II
Patriot Torqx 128GB Indilinx Barefoot Yes SATA II
Kingston 30GB V Series SNV125-S2 Toshiba T6UG1XBG Yes SATA II
Kingston 128GB V Series SNV425-S2 JMICRON JMF618 Yes SATA II
Corsair Force Series 100GB Sandforce SF-1200 (SF-1222) Yes SATA II
Corsair Nova Series 128GB Indilinx Barefoot Yes SATA II
Intel X25-M 160GB G2
Micron RealSSD C300 256GB Marvell 88SS9174 Yes SATA III
* TRIM is not supported due to the RAID controller.
In the readout on CrystalDiskInfo 4.1.3 shows that both NCQ and S.M.A.R.T. are enabled, as well as TRIM and the interface is SATA 6Gbps. This is a great free tool to see lots of detailed information about the drive such as the firmware version which is listed as GFW3.3.2.
RunCore Pro V 120GBCRYSTALDISKMARK INFO
On to the benchmarks!
