RunCore Pro V 120GB Solid-State Drive Review
HD Tach & CrystalDiskMark Synthetic Benches
HD TACH 3.0.4.0
HD Tach is a low level hardware benchmark for random access read/write storage devices such as hard drives, removable drives (ZIP/JAZZ), flash devices, and RAID arrays. HD Tach uses custom device drivers and other low level Windows interfaces to bypass as many layers of software as possible and get as close to the physical performance of the device as possible.
RUNCORE PRO V HDTACH
RUNCORE PRO V HD TACH GRID
Benchmark Results: The RunCore Pro V again shows the same performance as the other SATA II based SF-1200 drives we have tested. It doesn’t look like anyone is going to squeeze more performance out of this controller.
CrystalDiskMark 3.0.0h
RUNCORE PRO V CRYSTALDISKMARK
RUNCORE PRO V CRYSTALDISKMARK GRID
Benchmark Results: The 4k write score was slightly below what we saw on similar drives but close enough that no real world difference would be discernable.
