RunCore Pro V 120GB Solid-State Drive Review
RunCore Pro V 120GB – Test System
TEST SYSTEM
All tests were performed on a fresh and up-to-date install of Windows
7 Pro x64 with no
other applications running while using AHCI mode set through the BIOS.
Synthetic Benchmarks were run with the OS loaded on a 40GB Corsair Force
SSD. The
ASUS P6T Deluxe (BIOS v1701) motherboard uses an ICH10R south bridge
chipset which supports
TRIM. In between every test, the drive was secure erased. As such, all
results should be
indicative of optimal performance. All
components were set to their default speeds and are listed below.
LR TEST BENCH
Intel LGA 1366 Test Platform
Component Brand/Model Live Pricing
Processor
Core i7 920
Motherboard
ASUS P6T Deluxe V1 (1701)
Memory
CORSAIR XMS3 3GB DDR3 1333
Video Card
Gigabyte GeForce GT 430
OS Drive
Corsair Force 40GB
Power Supply
Corsair HX1000
Operating System
Windows 7 Pro 64-Bit
Comparison Drives & Other Models We Have Tested
Since there are so many SSDs out there now with different
controllers, we started a reference table of which
controllers are used by each drive to help you compare results.
Different controllers definitely perform differently and each has various strengths and weaknesses. Like CPU’s, even identical drives will have variations in performance and part of that variance may be attributable to the NAND flash used.
SSD
MODEL
CONTROLLER(S) TRIM Support?
Samsung 470 Series 256GB
Samsung S3C29MAX01-Y340 Yes
Zalman N Series 128GB SandForce SF-1200 (SF-1222) Yes
Kingston V+100 128GB Toshiba T6UG1XBG Yes
Corsair Force 40GB Sandforce SF-1200 (SF-1222) Yes
Intel X25-V 40GB Intel G2 Yes
G.Skill Phoenix Pro Sandforce SF-1200 (SF-1222) Yes
Patriot Inferno 100GB Sandforce SF-1200 (SF-1222) Yes
OCZ RevoDrive X2 240GB SSD (4X) Sandforce SF-1200 (SF-1222) No*
OCZ RevoDrive 120GB SSD (2X) Sandforce SF-1200 (SF-1222) No*
ADATA S596 128GB JMicron JMF612 Yes
Corsair Force Series 120GB Sandforce SF-1200 (SF-1222) Yes
Patriot Zephyr 128GB JMICRON JMF612 Yes
Patriot Torqx 128GB Indilinx Barefoot Yes
Kingston 30GB V
Series SNV125-S2
Kingston 128GB V
Series SNV425-S2
JMICRON JMF618 Yes
100GB
Corsair Nova Series
128GB
Intel X25-M 160GB G2 SSD
Intel PC29AS21BA0 Yes
Micron RealSSD C300 (6Gbps) 256GB Marvell 88SS9174-BJP2 Yes
* TRIM is not supported due to the RAID controller.
The readout on CrystalDiskInfo 3.9.1, both NCQ and S.M.A.R.T. are
enabled, as is TRIM. This is a great free tool to see what version of
firmware the drive is running in the event there are updates
available.
RUNCORE PRO V CRYSTALDISKMARK INFO
On to the benchmarks!
