RunCore Pro V 120GB Solid-State Drive Review
Introducing the RunCore Pro V 120GB SSD
RunCore is not exactly a household name in the industry as they have only been around since 2007, evolving from a company that focused on military product design. According to their website, they released their first SSD in September of 2007 so they’ve been in the SSD business just as long or longer than other more well known SSD makers. Their most recent consumer SSD is the fifth generation in their “Pro” line and aptly named as the Pro V. We received the 120GB (RCP-V-S251B-MC) version to run it through our usual battery of tests.
RUNCORE PRO V FRONT
The drive itself is gorgeous with a brushed aluminum shell and the RunCore logo and name engraved on the front. If you have a case that shows off your internal hardware, this would fit right in with an elegant look. Performance-wise, the drive is capable of read/write speeds of 260MB/s which is what we would expect to see from a SandForce drive.
RUNCORE PRO V BOX
Originally available in 2010 in capacities of 50GB, 100GB and 200GB, the firmware and product line has been refreshed to reduce the overprovisioning and offer capacities of 60GB, 120GB and 240GB. All can be found online at RunCore’s store for $189.99, 319.99 and $549.99 respectively. I could only locate this drive at a few obscure online retailers which may be why their brand is not so prominent.
RunCore Pro V Features and Specifications:
Overview Interface SATA
Dimension 100.2mm x 69.8mm x 9.8mm
Capacity 60GB 120GB 240GB
Flash Media MLC NAND Flash
Performance Sequential Read 260MB/s
Sequential Write 260MB/s
4KB random read 30000 IOPS
4KB random write 10000 IOPS
Electrical Specification Input Voltage 5V 5%
Power Consumption Operational = < 1.0 W
Idle = 650 mW
Reliability/Stability Data Encryption: 128-bit AES-compliant, Optional disk password
Supports 5-year consumer life cycle
MTBF:2,000,000 hours
Temperature Work Temperature Commercial Grade ( 0?~?70?)
Storage Temp -45C~+90C
Weight < 140g
RUNCORE PRO V CONTENTS
In the box, in addition to the drive we find a USB 2.0 enclosure, a USB 2.0 data cable, a small screwdriver with screws (for the enclosure), a SATA II to USB 2.0 connector card and a couple of RunCore stickers. Included on the drive is also software for data migration – Acronis Migrate Easy (PC) and Carbon Copy Cloner (Mac). The drive carries a two year warranty thought the life cycle is rated for five years.
RUNCORE PRO V BACK
The back is rather unremarkable with a sticker containing the usual model number and legal information affixed to the center. Let’s move inside the drive.
