Rosewill Launches Companies First 80 Plus Platinum Power Supply – FORTRESS
Rosewill just released their first 80+ Platinum certified power supply. Codenamed FORTRESS, it is the first among several 80+ Platinum certified power supplies that will be added to their already distinguished line of power supplies. With an efficiency rating up to 94%, youll get the maximum performance from every FORTRESS power supply which will be available in 450W, 550W, 650W, and 750W ratings.
The 80+ Platinum rating translates into cooler temperatures across the board which provided the opportunity to use a silent 135mm fan. Equipped with a single 12V rail that outputs up to 62.5A and comes with four 6+2 PCI-e connectors on the 750W model, you can power almost any combination of two video cards on the market. Coupled with the 80Plus Platinum Certification, youre components will be getting clean and efficient power at all times.
