Rosewill Capstone 750W Power Supply Review
Rosewill Capstone 750W Power Supply Review Introduction
Several large retailers and
e-tailers around the globe have started their own in-house brands. While these in-house
brands are usually limited to input peripherals and minor accessories, the
largest companies do offer more in-house products, such as computer cases and
power supplies. Rosewill however is perhaps the first company which expanded to a full-fledged manufacturer and exporter, even though they initially started as an in-house brand. Rosewills product catalogs are
vast, ranging from the simplest accessory to the high end gaming cases and
power supplies. However, as the company just started acting as a stand-alone manufacturer, it is natural for users to be concerned whether their end products can truly stand their ground against well-established manufacturers. Today we will address some of these concerns through the review of the Rosewill Capstone 750W power supply.
Rosewill Capstone Series power supplies
The Rosewill CAPSTONE series is available in 450, 550, 650 and 750 Watt models in your choice of either modular or non-modular cables. All of the power supplies are 80 PLUS GOLD Certified, feature a single 12V rail and use a large 140mm fan to keeps things cool and quiet. All of the power supplies are 150 x 86 x 163 mm (W x H x D) and come back by a 5-year direct replacement warranty.
Model
Watts
Modular
Price
Rosewill CAPSTONE 450 450W $69.99
Rosewill CAPSTONE 450-M 450W Yes $64.99
Rosewill CAPSTONE 550 550W $74.99
Rosewill CAPSTONE 550-M 550W Yes $69.99
Rosewill CAPSTONE 650 650W $99.99
Rosewill CAPSTONE 650-M 650W Yes $99.99
Rosewill CAPSTONE 750 750W $114.99
Rosewill CAPSTONE 750-M 750W Yes $99.99
Rosewill sent us the Capstone 750W non-modular power supply to review today. This power supply has a single +12V rail rated at 744W output and 62 Amps. This is an 80 Plus Gold
certified power supply unit, which is
designed and made by a highly reputable OEM and is not your cheap $30-40 “generic” product. Rated at 50C ambient temperature,
the specifications of this power supply are very interesting, although not as
interesting as the retail price; with the Capstone 750W retailing for $114.99 + $3.99 shipping at the time of this review, it is
one of the cheapest 750W 80Plus Gold certified power supplies currently
available. As you can tell from the chart above, pricing for the Rosewill Capstone PSU series is all over the place right now as the modular power supplies are part of a promotion right now and cost less than the non-modular versions!
Rosewill Capstone-750
Rosewill CAPSTONE 750W PSU Features:
  • 80 PLUS
    GOLD Certified
  • Continuous
    750W @ 50C
  • Single strong
    12V rail idea for Gaming system
  • SLI &
    CrossFire Ready 4 x 6+2pin Connector
  • 1 x Silent
    140mm Fan with Auto Fan Speed Control for better silence
  • Active-PFC
    with auto AC-input voltage adjustment (100-240V)
  • Mesh
    sleeving on all cables for easier cable routing and better ventilation
  • Over
    Temperature / Current / Voltage / Power Protection, Under Voltage Protection,
    and Short Circuit Protection provide maximum safety to your critical system
    components
  • Safety
    & EMI Approval: cTUVus, FCC, CE, ROHS
Rosewill CAPSTONE 750W PSU Specifications:
Type
ATX12V v2.31 & EPS12V v2.92
Maximum Power
Continuous 750W @ 50C
Fans
1 x Silent 140mm Fan
PFC
Active
Main Connector
20+4Pin
+12V Rails
Single
PCI-Express Connector
4 x 6+2-Pin
SATA Power Connector
8
SLI
Ready
CrossFire
Ready
Modular
No
Power Good Signal
100-500ms
Hold-up Time
> 16ms
Efficiency
> 87%, Up to 92%
Energy-Efficient
Over Voltage Protection
+3.3V, +5V, +12V
Input Voltage
100 – 240 V
Input Frequency Range
47 – 63 Hz
Input Current
10A
Output
+3.3V@24A, +5V@24A, +12V@62A
[email protected], +5VSB@3A
MTBF
100k hours at 25C, max. load, nominal
input
Approvals
Dimensions
5.91″ x 3.39″ x 6.42″
(W x H x D)
