RIOTORO Unveils First PC Chassis with Customizable 256 Color RGB Lighting
Los Angeles, California January 5, 2015 RIOTORO, a new California based company dedicated to building innovative PC components with leading-edge features and performance, today announced the Prism CR1280 full tower PC case with integrated RGB LED lighting that users can customize to any of 256 colors. Easy to build and customize, the cases elegant windowed exterior surrounds a compartmentalized steel frame optimized for airflow for extreme performance at whisper quiet levels. The Prism CR1280 will be available in February at an introductory price of $139.99.
The first full tower PC case with integrated LED lighting, the RIOTORO Prism CR1280s front panel trim and dual LED fans can be set to any one of 256 colors from the front panel, enabling users to customize their systems color scheme to match their personal style or mood.
Born to Cool
The Prism CR1280 has separate compartments for the motherboard, power supply and drives to help direct airflow over critical components and isolate sensitive drive storage. The included dual front and rear 120 mm fans provide direct airflow from front to back cooling the CPU, GPU and motherboard. Additional mount points for users that want to add more fans or liquid cooling radiators.
Prism 280 RGB Front Panel
The Prisms front panel allows users to quickly select either of two fan settings. Performance Mode increases fan speed for increased cooling for extreme GPU and CPU overclocking to boost performance during rigorous game play or processor intensive tasks like video rendering. Low-Key mode reduces fan speeds to ample cooling for simple everyday tasks while reducing noise.
Builder-Friendly
Riotoro Prism CR1280 with windowed panel
The spacious interior incorporates modern builder-friendly features easy installation and customization. The integrated cable management in the Prism CR1280 is carefully designed to provide optimal routing paths and tie down points allowing users to easily secure and conceal loose cables. The reduced cable clutter allows for an unobstructed of the rigs interior through the side window while greatly improving airflow to critical components.
“The Prism CR1280 is a compendium of what we have learned in the components industry over many years, said Nelson De Moraes, Worldwide VP of Sales and Marketing at RIOTORO. What we focused on was building a case that has integrated all of the features that enthusiasts care about and want, then we added a few of our ownand that is how the RIOTORO Prism case came to life.
Warranty, Pricing, and Availability
The RIOTORO Prism CR1280 case is backed by a two year warranty and technical support.
RIOTORO Prism RGB Case
The case will be available in February for an introductory price of $139.99 USD from Amazon.com.
For more information on the RIOTORO Prism CR1280, please visit:
http://riotoro.com/prism-cr1280
