Realtek Launches DisplayPort HBR3 LCD Monitor Solution
Realtek Launches the Worlds First DisplayPort HBR3 (8.1Gbps) LCD Monitor Solution Supporting 5K@60Hz or 4K@120Hz Display via a Single DisplayPort Cable
HSINCHU, Taiwan May 31, 2016 Realtek Semiconductor Corp. (Taiwan Stock Exchange: 2379.TW), one of the worlds leading network and multimedia IC providers, today announced the worlds first DisplayPort HBR3 (8.1Gbps) LCD monitor solution (RTD2185 + RTD2799) supporting 5K or 4K display via a single DisplayPort cable.
The Realtek RTD2185 + RTD2799 solution allows a single DisplayPort cable to support both ultra-high 5K@60Hz display and 4K ultra frame rate 120Hz display. This solution provides multiple HDMI 2.0, DisplayPort HBR3 (High Bit Rate 3), and MHL digital inputs. The HDMI 2.0 receiver PHY supports up to 6GHz, allowing true UHD 4:4:4 color transmission at 60Hz frame rate. Built-in support for Multi-Stream Transport (MST) technology enables end-users to easily daisy-chain multiple monitors via a simplified configuration.
Realteks RTD2185 + RTD2799 solution enables monitor makers to bring to the market top-of-the-line, flagship monitors with the highest resolution and highest frame rate using a single DisplayPort cable, said Realteks Vice President and Spokesman, Yee-Wei Huang. DisplayPort HBR3 allows total bandwidth data transfers up to 32.4Gbps (4 lanes@8.1Gbps), which is a huge increase over DisplayPort HBR2. The higher screen resolutions and higher refresh rates provide outstanding gaming performance, as well as text and graphics that are rendered crisp and sharp.
All HDMI and DisplayPort interfaces adopt the latest High-bandwidth Digital Content Protection (HDCP) version 2.2, and support all 5K/4K panel interfaces.
In addition, the integrated MCU, audio DAC, advanced color engine, 3D Gamma LUT, VESA Adaptive-sync technology, 3rd generation Realtek Ultra-Vivid III image/video quality enhancement technology, Frame Rate Conversion (FRC), and Over-Drive (OD) provide a top quality highly integrated platform to meet all needs.About Realtek
Realtek Semiconductor Corp. is a world leading IC provider that designs and develops a wide range of IC products for communications network, computer peripheral, and multimedia applications. Products include 10/100/1000M Ethernet Controllers/PHYs, 10/100/1000M Ethernet Switch Controllers/Media Converter Controllers/Gateway Controllers, Wireless LAN Controllers & AP/Router SoCs, xDSL, VoIP Solutions, Bluetooth, xPON, IoT Solutions, Automotive Ethernet Solutions, High Fidelity Audio Solutions for Mobile and PC Applications, Clock Generators, Card Reader Controllers, Web Camera Controllers, LCD Monitor/ATV/DTV Controllers, and Digital Home Center Controllers. With advanced design expertise in RF, analog, and mixed signal circuits, and with strong manufacturing and system knowledge, Realtek offers full-featured, high-performance, and competitive total solutions. More information on Realtek can be found on our website: www.realtek.com
