PQI Releases Small USB Drive For Ultrabook Users – U280L
Power Quotient International (PQI) has just announced the launch of its all-new U280L 4GB USB Traveling Disk today. The devices small and compact design (18.6 x 15.4 x6.8 mm) was inspired by computer keyboards and, at a mere 0.68 cm thick, is roughly the same size as a single key. When plugged into an Ultrabook, Notebook, or Tablet PC, it remains firmly attached and takes up almost no extra space. This streamlined design eliminates cluttering issues common among other bulky flash drives. In addition, its compact low-profile makes it a durable and resilient partner, ensuring that data remains safe and secure wherever the user takes it. If you do happen to break it, the portable storage device comes with a lifetime warranty. Just make sure you don’t loose this little bugger as then you’ll be out of luck. The other downside of this product is that it is only available in a 4GB version, which is a little small considering how much data people move around these days.
The PQI U280L features a special sandblasted plastic exterior that is both sturdy and attractive. The casing is reminiscent of morning mist, and comes in two colors: aurora white and storm black. In addition, a glowing red LED indicator at the end of the drive flashes during data transfers to clearly signal the devices operation status. The U280L also comes with a free multipurpose chain which enables the device to be conveniently carried around as a stylish charm by attaching it to other personal items such as mobile phones, cameras, backpacks, and more.
