Plantronics Discovery 975 Bluetooth Headset Review
Discovery 975 – The Best Ever?
People will ask, Is this headset really better than the Jawbone or BlueAnt? If you are strictly measuring the overall quality of the headset by the sound volume and ability to dampen or reduce environmental noise, then picking a winner out of this lot is a toss-up. On the other hand, if you are looking for the best sounding, best looking, most comfortable, and longest battery life in the bunch, the Plantronics Discovery 975 wins hands down.
The fact that Plantronics improved their battery case and included a never-before-seen LCD screen to give you battery status on the headset and case is amazing and much appreciated. The Plantronics engineers even designed a latching system that helps to release the Discovery 975 easier than the previous design.
If you are going to spend around $120 on a Bluetooth headset you expect it to do everything well. Plantronics Discovery 975 does indeed do everything well. The sound quality, the look and feel, the battery life, and the recharging case make this the best Bluetooth headset on the market today.
Legit Bottom Line:
The best just got better. Plantronics has improved its Discovery line of Bluetooth headsets with the $120 Discovery 975. With better sound quality and a newly designed charging case, the Discovery 975 is the best Bluetooth headset on the market today and earns Legit Reviews Editors Choice Award!
