Patriot Xporter XT Rage 32GB USB 2.0 Flash Drive Review
Testing Round 1 – ATTO Disk Benchmark
ATTO measures transfers across a specific volume length. It measures raw
transfer rates for both reads and writes and places the data into
graphs that can be very easily interpreted. The test was run with the
default runs of 0.5kb through 8192kb transfer sizes with the total
length being 256mb.
This benchmark proves that the rated transfer speeds hold up through most tests between 64KB and 8MB file sizes, which is a good range that most small file transfers, such as picture and music files, are made up of. These small transfers make up a good portion of what many people will do on a day to day basis.
The Patriot Extreme Performance Xporter Rage USB 2.0 Flash Drive was able to reach ~28MB/s read and ~24MB/s write when using the ATTO benchmark tool.
