Patriot Viper II Sector 5 2000MHz 4GB Memory Kit Review
Final Thoughts on the Patriot Viper II Sector 5 Kit
If you are looking to squeeze every ounce that you can get out of your system, you will need some headroom when it comes to your memory. The Viper Sector 5 DDR3 2000 kit will certainly give you what you need for headroom. It also performs fantastically, and the retail kit also has a great design and look to it.
This kit retails right at $220 from several different online retailers at the time of press. This price is on the higher end of 4GB kits, but this kit does come with a lifetime warranty and is a solid build. Patriot has a great reputation, and that will only continue with the Patriot Viper Sector 5 DDR3 2000 4GB kit.
Legit Bottom Line: This is a great kit that gives you plenty of headroom for overclocking. It is backed by a lifetime warranty, and has the solid Patriot name behind it. If this is in your price range, it is certainly a kit that you should consider putting in your system.
