OWC Mercury EXTREME Pro 6G 120GB SSD Review
CrystalDiskMark and PCMark Vantage
CrystalDiskMark 3.0.1 – Intel P67 Platform
OWC Mercury Extreme Pro 6G CRYSTALDISKMARK P67
Benchmark Results: Again, strong numbers here by the OWC Mercury EXTREME Pro 6G – especially for a SandForce drive which doesn’t typically fare as well with incompressible data employed by this benchmark. The 4k writes were significantly higher than any other SATA 6Gbps drive except the Vertex 3 120GB.
OWC Mercury Extreme Pro 6G CRYSTALDISKMARK GRID
PCMark Vantage 1.0.2.0 – Intel P67 Platform
PCMark Vantage v1.01 measures the performance of the latest PC hardware across a variety of common scenarios. PCMark Vantage supports both system level and component level benchmarking and comprises several different test suites but for the purposes of this review, we stuck with just the HDD suite. The nice thing about PCMark Vantage is that you can submit your scores online and compare against others.
OWC Mercury Extreme Pro 6G PCMARK VANTAGE
Benchmark Results: The scores are very good as we expect to see from the latest generation SandForce drives which consistently have strong showings on this benchmark.
OWC Mercury Extreme Pro 6G PCMARK VANTAGE GRID
