OWC Mercury EXTREME Pro 6G 120GB SSD Review
Comparison Drives and Test System
Legit Reviews Test System
All tests were performed on a fresh and up-to-date install of Windows 7 Pro x64 with no other applications running while using AHCI mode set through the BIOS. Synthetic Benchmarks were run with the OS loaded on a 40GB Corsair Force SSD. In between every test, the drive was secure erased using Parted Magic. As such, all results should be indicative of optimal performance. All components were set to their default speeds and are listed below and we’d like to thank ASUS for their generosity and support in providing the motherboard for our test bench.
LR Test Bench
P67 Test Bench
Intel LGA 1155 Test Platform
Component Brand/Model Live Pricing
Processor
Core i5 2500k
Motherboard
ASUS P8P67 Deluxe
Memory
Crucial 2 x 2GB PC3-10600
Video Card
Gigabyte GeForce GT 430
OS Drive
Corsair Force 40GB
Power Supply
Corsair HX1000
Operating System
Windows 7 Pro 64-Bit
Comparison Drives & Other Models We Have Tested
Since there are so many SSDs out there now with different controllers, we started a reference table of which controllers are used by each drive to help you compare results.
Different controllers definitely perform differently and each has various strengths and weaknesses. Like CPU’s, even identical drives will have variations in performance and part of that variance may be attributable to the NAND flash used. Since the tests of the drives listed have spanned different test benches and represent three different interfaces, we have listed them for easy reference.
SSD
MODEL
CONTROLLER(S) TRIM Support?
Crucial m4/Micron C400 256GB
Marvell 88SS9174 Yes
Intel 320 Series 128GB
Intel PC29AS21BA0 (G3 firmware) Yes
Corsair Performance 3 Series 128GB
Intel 510 Series 250GB
Plextor M2 Series 128GB
Kingston V100 Series 128GB
JMicron JMF618 (Toshiba branded) Yes
OCZ Vertex 3 Pro 200GB (beta) SandForce SF-2500 (SF-2582) Yes
RunCore Pro V 120GB
SandForce SF-1200 (SF-1222) Yes
Samsung 470 Series 256GB
Samsung S3C29MAX01-Y340 Yes
Zalman N Series 128GB SandForce SF-1200 (SF-1222) Yes
Kingston V+100 128GB Toshiba T6UG1XBG Yes
Corsair Force 40GB Sandforce SF-1200 (SF-1222) Yes
Intel X25-V 40GB Intel PC29AS21BA0 (G2 firmware) Yes
G.Skill Phoenix Pro Sandforce SF-1200 (SF-1222) Yes
Patriot Inferno 100GB Sandforce SF-1200 (SF-1222) Yes
OCZ RevoDrive X2 240GB SSD (4X) Sandforce SF-1200 (SF-1222) No*
OCZ RevoDrive 120GB SSD (2X) Sandforce SF-1200 (SF-1222) No*
ADATA S596 128GB JMicron JMF612 Yes
Corsair Force Series 120GB Sandforce SF-1200 (SF-1222) Yes
Patriot Zephyr 128GB JMICRON JMF612 Yes
Patriot Torqx 128GB Indilinx Barefoot Yes
Kingston 30GB V
Series SNV125-S2
Kingston 128GB V
Series SNV425-S2
JMICRON JMF618 Yes
100GB
Corsair Nova Series
128GB
Intel X25-M 160GB G2 SSD
Micron RealSSD C300 (6Gbps) 256GB Marvell 88SS9174 Yes
* TRIM is not supported due to the RAID controller.
In the readout on CrystalDiskInfo 3.10.0, both NCQ and S.M.A.R.T. are
enabled, as is TRIM. This is a great free tool to see what version of
firmware the drive is running in the event there are updates
available.
OWC Mercury Extreme Pro 6G CRYSTALDISKMARK INFO
On to the benchmarks!
