OCZ Blade DDR3 6GB 2000MHz Memory Review
Sandra 2009 Memory Bandwidth
The Sisoft Sandra 2009 benchmark utility just came out recently and we have started to include it in our benchmarking. With Sandra 2009 you can now easily compare the performance of the tested device with its speed and its (published) power (TDP)! Sandra XII SP2 also has SSE4 (Intel) and SSE4A (AMD) benchmark code-paths, which is great for those of you testing next-generation AMD & Intel chips.
Results: Both memory kits have an incredible amount of bandwidth with both kits approaching mid 30GB/s!
