OCZ Blade DDR3 6GB 2000MHz Memory Review
A Closer Look
The box that this memory comes in is all business, black and white.
Getting up close and personal with one of the three modules, you can clearly see the specifications, PC3 16000 which equates to DDR3 2000MHz. 7-8-7 timings with a required voltage of 1.65v, clearly in-line with what Intel specifies as the max 24/7 operating parameter for the longevity of your CPU.
This photo shows just how much smaller the Blade Series heat spreaders are than what are probably the largest on the market, the HyperX T1.
On the back side of the module is, well, not much. To remove the heat spreader simply unscrew the two screws at the back. As I said earlier, this memory means business, let’s take a look at what they will do.
