NZXT Kraken X40 & X60 CPU Water Cooler Reviews
The Test System
- NZXT Kraken x40 or x60 Liquid CPU Cooler
- 16GB Corsair Vengeance Pro 1866MHz Memory
- GIGABYTE Z87X-UD4H Motherboard
- 2x 120GB Samsung 840 Pro SATA III 6Gb/s SSDs in RAID 0
- Thermaltake Pure Power 680w Power Supply
- Windows 7 Professional Operating System
- Fractal Design Define XL R2 Case
Intel Z87/LGA1150 Platform
The Intel Z87 platform that we used to test these memory modules was running the GIGABYTE Z87X-UD4H motherboard with BIOS version F7 that came out on 08/05/2013. The processor used, the Intel Core i7 4770k, will be using the stock frequency of 3.5GHz with turbo boost enabled, which can boost it up to 3.9GHz. Low power state is enabled, which clocks the CPU at 900MHz.
