NZXT KRAKEN X31 120mm Water Cooler Released w/ Variable Speed Pump
NZXT Releases the 120mm Variable Speed Liquid Cooling Kit Kraken X31
NZXT Kraken X31
Los Angeles, CA NZXT today takes the Kraken liquid coolers line to new depths with the Kraken X31 by re-imagining the 140mm platform in a smaller, more affordable 120mm package without sacrificing the performance the Kraken has come to be known for.
Releasing the 120mm Kraken
By utilizing a 120mm radiator, NZXT has increased the Kraken radiator line’s compatibility to include cases that dont support our 140mm standard. The X31 radiator is also optimized to run on a single fan without losing static pressure, airflow, or performance. Extended tubing make installing the Kraken X31 a breeze, while our industry leading six year all-inclusive warranty keeps your rig performing reliably at top performance.
Variable Speed Pump
The Kraken X31 includes the same state-of-the-art integrated variable speed pump that keeps noise to a minimum during use without sacrificing top end pump power as in the X41 and X61. A single 120mm pressure-optimized PWM fan connects directly with the pump to give complete software control over your Kraken cooler.
NZXT-CAM
NZXT-CAM
Control the Kraken with CAM
In addition to the unmatched performance and a robust warranty, our legacy Kraken Control software has been replaced by the Kraken+ module within our new software suite, CAM. CAM allows DIY enthusiasts to control the Kraken X31’s fan speeds other custom cooling settings directly from a PC or mobile device regardless of where you are in the world via its Kraken+ module.
The Kraken X31s mix of performance, affordability, and reliability makes this is the perfect time to take the plunge and Release the Kraken!
Price and Availability
The Kraken X31 is available immediately for pre-order exclusively at the NZXT Armory Store for US$79.99 with an anticipated ship out date of mid-July.
Product photos and detailed specs are available at: http://www.nzxt.com/
Visit NZXT Facebook https://www.facebook.com/NZXTcorp
About NZXT
Founded in 2004, NZXT is dedicated to manufacturing the best gaming hardware for consumers worldwide. With the unveiling of every product, NZXT improves upon on weaknesses and strives for excellence. Achieving perfection is not an easy task, however, NZXT is determined to meet and surpass consumer expectations. For more information about NZXT, visit the NZXT website at www.nzxt.com.
