NZXT Havik 140 CPU Cooler Review
Unboxing the NZXT Havik 140
NZXT Havik 140 CPU Cooler box wrap
The Havik 140 comes in a nice, sturdy box and sealed in plastic wrap.
NZXT Havik 140 CPU Cooler box side
On one side of the box is the socket compatibility listing and a nice side shot of the cooler.
NZXT Havik 140 CPU Cooler box back
On the back of the box is the specifications listing and images of the cooler with brief descriptions.
On the other side is another side image of the cooler. There is also some text going over the features of the Havik 140.
NZXT Havik 140 CPU Cooler box sealed
The box also has a seal on it. So if for some reason the outer plastic is gone, you will know if the box has been opened.
NZXT Havik 140 CPU Cooler fan packing
When you first open the box you see one of the 140mm fans cradled in foam.
NZXT Havik 140 CPU Cooler more fan packing
Under that is the second fan in another tray.
NZXT Havik 140 CPU Cooler packing
Under that is the cooler body in its tray. The body is wrapped in plastic as well.
