NZXT FX-140 Unboxing
Like we saw before, we’ve got much of the fans specs and information on the front of the box. It is a 9 Blade, Liquid Bearing fan with 3 Speed Fan Control built on, back by a 2 Year Warranty.
On the back of the box, we’re greeted by the familiar multi-table layout with the same four languages.
NZXT FX Enthusiast Series FX-140RB Fan Specifications
Size (Dimensions) | 140mm x 140mm x 25mm | ||
Bearing | Fluid Dynamic Bearing (FDB) | ||
Lifetime (MTBF) | 35,000 Hours @ ??C | ||
Settings | Low | Medium | High |
Current | 0.13A | 0.25A | 0.55A |
Input | 1.56w | 3w | 6.6w |
Speed (RPM) | 1000RPM10% | 1500RPM10% | 2000RPM10% |
Airflow (CFM) | 49.1 CFM | 73.8 CFM | 98.3 CFM |
Air Pressure | 0.56mmH20 | 1.3mmH2O | 2.2mmH20 |
Sound Pressure | 22.1dB(A) | 30.8dB(A) | 37dB(A) |
For our final fan in this roundup, we have the FX-140RB. Another Dynatron built and it easily mimics the design of their standard 140mm fan design. So this is definitely an upgrade with the Fluid Dynamic Bearing plus higher RPM output.
