NZXT Debuts Sleeved LED Kit
If you are in the mood for a little more flash in your PC, the NZXT sleeved LED kit may be for you. The NZXT sleeved LED kit is esigned to be an easy solution to add a bit more flare!
NZXT, a company built on realizing the dreams of gamers worldwide, is proud to unveil a fresh approach to case lighting with the Sleeved LED Kit. Traditional lighting methods involve cold cathodes and even solid LED boards that take up additional case space. NZXTs unique design pairs sleeved wires with a high density of LEDs, enabling enthusiasts to snake the lights between side panels and under components with ease. The end result is a beautiful glow throughout the case with a clean installation that doesnt detract from the internal aesthetics.
