NZXT Classic Series H2 Silent PC Case Review
Inside the H2 Continued
Moving to the rear of the case we can see that the power supply is supported and isolated with 4 rubber pads. In front of the power supply is the lower intake vent for a user installed 120mm fan.
The expansion slot covers are made of mesh and held in place with thumb screws.
At the top rear we can see the rear 120mm exhaust fan and the USB3 cable. The power wire for the fan is pre-run behind the motherboard tray.
Moving around to the right we can see behind the motherboard tray.
All of the front panel wiring, installed fan power wires, and the USB3 cable are not only pre-run for you, but are held in place with zip ties.
Up on the front are the power connectors for the front Touch Power PCBs. The wires run to the fan controller on the front panel. The Fan controller has 2 open connectors for user installed fans for the lower intake fan in front of the PSU and the top exhaust fan.
