Low Voltage In-Wall Box Routes Cables Behind Mounted TV
Sanus Systems announced that they are shipping the Sanus Elements ELM803 Recessed Low Voltage In-Wall Box for a list price of $19.99 USD. The ELM803 installs behind a mounted flat-panel TV, allowing the TV to sit as close to the wall as possible, and routes cables neatly through the wall for a flawless home theater installation. The box can be mounted on sheetrock walls using the built-in work tabs or attached directly to select Sanus mounts with removable ClickFit brackets. The brackets easily snap onto the mount for a clean installation with no drilling or wall mounting required. This might be of value for someone that gets a new HDTV this holiday season!
![Sanus Elements ELM803 Recessed Low Voltage In-Wall Box Sanus Elements ELM803 Recessed Low Voltage In-Wall Box](http://legitreviews.com/images/news/2009/elm803.jpg)
“With the introduction of ultra-thin mounts, TVs can be placed an inch or less from the wall,” said Steve Frank, Sanus director of product management. “The TV looks great but it’s often more difficult to install electrical boxes in the wall behind the mount and still have room to plug cables into the outlets. The ELM803 solves this problem with an in-wall wiring solution and plenty of space for cable management that’s also easy to install.”
